It is currently Mon Aug 11, 2025 1:02 am
PostPosted: Tue Oct 06, 2009 8:12 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Hi all. I am workin on a Cocobolo B/S guitar. the neck "mahogany" feels way to bright for being a good match. Question is. what are you guys using for tinting the neck. Just want it one step darker/redish or brownish. Can I use any kind of water/alcohol based tint ? or is there anything you would recommend. also whats the best way to put it on. Drytime/sand etc. procedure!:
Thanks in advance,
Lars.
PostPosted: Tue Oct 06, 2009 8:26 pm
Thanks in advance,
Lars.
There are a lot of good solutions and good products available. I would stay away from water based as I don't like to introduce any moisture into the wood....specially the neck.
PostPosted: Wed Oct 07, 2009 6:09 am
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Thanks Peter.
If anyone else has more info , It would be most appretiated.
Lars
PostPosted: Wed Oct 07, 2009 7:13 am
Here's a mahogany / EIR one I did with the Colortone liquid stains from Stewmac. I used medium brown, tobacco brown and possibly some vintage amber, all reduced in alcohol and applied to the bare wood with a rag. This instrument was then finished with nitro.
PostPosted: Wed Oct 07, 2009 10:13 am
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Thanks alot Arnt. great info and help. I was just looking at those colors at stewmac. will get them then. [:Y:] [:Y:]
Lars.
PostPosted: Wed Oct 07, 2009 5:51 pm
From another thread
bluescreek wrote:
I use CA to fill and as for necks , if you want to get a good match to the rosewood , I use red mahogany stain first follwed by Dark brown Mahogany stain , then use a blackened filler. I will go to 320 grit to stain and fill . If the stain doesn't work even I will use 320 grit sandpaper and sand stain to even the color.
I don't use water stains but have used aniline dyes
Formerly JJH
PostPosted: Thu Oct 08, 2009 6:10 am
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Thanks alot John for finding the info . and also thank you John Hall for the writing the info :D .
I have 2 bottles on the way now. one is Red mahogany stain and the other is medium brown same type as Arnt suggested. so hopefully it will go fine :? . will post photos as I am done !! .
Lars.
Users browsing this forum: Colin North and 42 guests
